I am looking at the 1000w amp on this auction ' 488886337' and im not sure if it will power my 12inch 1000w sony xplode sub and my 310w 6x9s
jasongroves,
Jun 28, 4:45pm
Use real figures, as you were advised in your other thread, those numbers mean squat. Fusion FR4-1000x Specifications:
4 x 125w RMS @ 4ohms 2 x 250w RMS @ 4ohms bridged 2 ohm stable THD 0.05% Signal to noise ratio 92dB Frequency Response 20Hz - 40KHz Variable High Pass Crossover(80Hz - .2KHz) (separate adjustment for front and rear) Variable Low Pass Crossover (40Hz - 150Hz) (separate adjustment for front and rear) Variable Bass Boost (0 - 12dB) (separate adjustment for front and rear)
jasongroves,
Jun 28, 4:47pm
Actually, it doesn't really seem like you have listened to any of the very good advice by knowledgeable posters in your other thread anyway.
rodg.sue,
Jun 28, 4:48pm
Sorry mate. Ive got absolutely no clue what any of that means. Will it work fine or do i need something different!
andrea_w,
Jun 28, 4:48pm
Yes it will. but I'd never have fusion in my car, even if someone paid me. So you've ignored all the advice you got and you're doing it your way, that's all good but enjoy the terrible sound quality you'll get (even though you wanted the opposite). A tad confused why you needed to start a new thread too. You're still going to need an aftermarket stereo to run the amp, 2 x RCA preouts would be recommended.
jasongroves,
Jun 28, 4:50pm
Your 1000w sub will be more like 250-300w RMS depending on age/model, your speakers most likely about 60w RMS, so yes, the amp will work.not perfect, but it will function.
rodg.sue,
Jun 28, 4:56pm
Im planning on putting a SonyCDXGT610UG in it! And what amp would suit it best then!
rodg.sue,
Jun 28, 4:59pm
Oh and whats RMS! haha
jasongroves,
Jun 28, 5:07pm
Root, mean, squared.
mm12345,
Jun 28, 5:07pm
Root Mean Square. It happens in the back of cars parked in the town centre of Palmerston North on Saturday nights.
jasongroves,
Jun 28, 5:08pm
Just use the Fusion amp. Set the levels and gains correctly to prevent clipping etc and it will do what you want it to.
