Hi there. my car is making a clonking noise when i turn full lock sometimes could it be the cv! Sometimes its quite loud
a.woodrow,
Sep 2, 8:03pm
front sway bar bushes and stones in the tops of the struts. Not cv's the commie is rwd
treachug,
Sep 2, 8:05pm
Sounds more like the sway bar link bushes are worn/split & need replacing. Also do the sway bar link rods as well.
inkapuka,
Sep 3, 4:36am
Oh yeah is that expensive!
splinter67,
Sep 3, 5:27am
Ask your mechanic if you think you have cvs
car27,
Sep 3, 7:35am
if its the sway bar link bushes theres usually a clunk when you hit a bump I just done mine cost $60 off trademe took about 40 minutes
jenny188,
Sep 3, 8:28am
My commodore makes the same "clonking" noise when onfull left lock. Think its caused by Pedestrians.
hopie,
Sep 3, 12:01pm
If your doing the sway bar link bushes you might as well spend the extra $40 and get the nolathane sway bar link as well. They are almost twice as thick and already pre bent. (just make sure you put them in facing the right way) as said above takes bugger all time (with a grinder)
