Toyota Hilux Brake Problem
brianna09, Sep 5, 8:14am
my brakes cut out about a month a go. It still has a little bit of brakes but not much! Can push it in about a centimetre or 2. Not mechanically minded need advice.
thunderbolt, Sep 5, 8:28am
Mechanic needed urgently.
mr_lovebug, Sep 5, 8:31am
Could it be case of just needing to be beeded!
brianna09, Sep 5, 8:40am
thanx. whats the difference if you know it needs to be bleeded or if it needs new brake pads all 2getha!
jmma, Sep 5, 8:49am
Don't piss around with brakes. Get them seen to now.
scuba, Sep 5, 8:56am
don't worry the tow truck driver will be able to advise you soonenough.
hopie, Sep 5, 12:56pm
Have a look thru the wheel spokes (or if you cant' take the wheel off) and you can see how much life is left on the pads. if it is reasonable try bleeding it. first step and cheapest.
franc123, Sep 5, 5:21pm
I see from your other thread it is diesel, can you go out to the truck, sit in the drivers seat, pump the brake pedal as hard as you can, using both feet, hold it down and then start the engine normally. Tell me if the pedal stays in the same position or you can feel it sink a bit under your feet after the engine fires up.
brianna09, Sep 17, 10:05am
thanks for this, I got my brother inlaw to have a look and it needs a new altinator in order for the brakes to work, something about suction or something like that.
intrade, Sep 17, 10:43am
its called a faulty vaccume pump
Post *8 was on to it.
guest, Sep 26, 8:45am
Hi, would you like to buy a white sturgeon? Fresh from The Environment. Each one comes pelronasly signed, With love, from Barry. Just say the word and my lil' red helper will get you one.
guest, Sep 29, 1:18am
People nolamlry pay me for this and you are giving it away!
