I have a 2005 toyota hilux SR5. It has a noise started in the left front corner somewhere. It sounds like bearing noise, So i have replaced the wheel bearings in that corner, but it is still there. It is the last of the old shape hilux, (before they went to the sheep shagger model). It has interdependent front end. Where do i go to from here!
muzzaandmich,
Jan 3, 2:13pm
Toyota dealership maybe you should have taken it to them in the first place If Toyota can't fix it who can
the_chooky,
Jan 3, 2:30pm
Brilliant answer.not.
a.woodrow,
Jan 3, 2:33pm
Well it could have saved them the wasted money and time guessing and replacing wheel bearings which didn't actually fix the problem
brbyr,
Jan 3, 3:12pm
Its more the fact that my local garage is still shut over the holiday period, and it is my only mode of transportation.
aj254,
Jan 3, 3:53pm
If its the model without freewheeling hubs it might be the cv joint.
