Ford Focus power steer
freddie19, Sep 25, 3:08pm
2001 Focus was leaking from the pressure sender unit which is on the line from the pump to the rack
I removed it and blocked off, there seems to be no lights come on and steering is fine
So my question is the purpose of this part
Can i do without it ?
bjmh, Sep 25, 3:10pm
does it still idle ok when you go lock to lock ?
franc123, Sep 25, 5:47pm
It is for maintaining idle speed for when the power steering pump is loaded up, its an on/off pressure switch. It may possibly cause momentary low idle speed condition, shuddering from the steering and maybe even log fault codes. I'd be interested to see what effect it has, its not fitted for no reason.
llortmt, Sep 26, 4:45am
It might just be like our tonsils franc!
kazbanz, Sep 26, 4:49am
Freddie--during "normal' driving you probably won't notice it. It will be parking you notice it the most.The car might stall for "no reason"
freddie19, May 6, 12:06pm
Thanks everyone for advice
New part ex Japan 10 days away but man need car to get to "kemo" treatments
Will keep you guys updated on cars behavior
