Brain storming, Fuel tank ideas
morrisman1, Apr 5, 8:58pm
looking for about 10-15L capacity. Doesn't have to be alloy, but if steel then nice thin like the factory tanks are. Id like it to fit in the factory position under the rear seat so that i can hook it up to the factory filler and it doesn't have to be isolated from the cabin (not as easy in a hatchback).
Can you think of existing vessels which might be suitable to modify?
clark20, Apr 5, 9:18pm
http://www.vpw.com.au/Category/Index/54
Have a look here, also look at boat tanks
morrisman1, Apr 5, 9:24pm
Nice tanks, but my budget was more like $100, rather than $500!
clark20, Apr 5, 9:25pm
Do you run a surge tank?
morrisman1, Apr 5, 9:29pm
I have one there which I can rig up. Is about a 2L capacity
morrisman1, Apr 5, 10:16pm
Had a measure up, have about 180mm between the bottom of the seat and the floor pan, so SFA. Might have to cut open the rear seat and make a box around like I did with the other car. That means a tall and narrow tank could be used and eliminate need for a surge chamber.
h.e, Apr 6, 6:48am
do you need a pump in the tank? If not what about a alloy air tank off a truck. Sure Des Grey motors would have hundreds lying around
clark20, Apr 6, 6:55am
Why do you want to do this the OE setup is probably lighter than a new one, and with a surge tank no worries with pickup
morrisman1, Apr 6, 7:12am
I only do sprints in this car, so racing for a couple minutes max. At the moment I need to lug around 20-30 litres just to stop it surging. Quite keen on getting rid of that weight. The factory tank is very shallow and wide, hence the surge. I have some external fuel pumps here so could convert over to a different pump if required. The factory fuel tank weighs about 8-10kg.
clark20, Apr 6, 7:26am
Remember 15 L less is 12Kg you are saving
Just run it with the surge tank in the engine bay and use a good inline pump, best of both worlds. Then just run minimum amount in the tank.
morrisman1, Apr 6, 7:33am
or another thought, I could modify the stock tank to be smaller. Reducing its capacity and weight and helping with surge. Get rid of the weight on the drivers side to offset my weight. I have a couple spare tanks I can play around with.
12kg is a lot, there are far more expensive ways to lose 12kg! Im making fibreglass panels and the bonnet saves me 15kg but at a lot of time and effort, doors are about 25-28kg saving each, boot 10kg. Race seat 10kg saving. All up Im saving 112kg, and if I can get another 15kg from the tank then that will be significant. A saving of 127kg total is equivalent to me adding 26hp. I like Colin Chapman's philosophy, but theres only so much you can do to a hatchback.
mrfxit, Apr 6, 7:35am
Boat tank.
Plastic or steel & made to withstand a reasonable amount of heat & trashing about complete with fittings & fuel gauge
clark20, Apr 6, 7:38am
I was thinking the same but once you cut and weld, I bet you do not save much, worth a try. Maybe mount a surge tank inside the original tank
http://www.lvvta.org.nz/documents/suplementary_information/HCTM_SAMPLE_Chapter-10_Fuel%20Systems.pdf
extrayda, Apr 6, 7:41am
Years back a mate got a tank in a falcon modified - I think they added baffle plates inside the tank, and also filled in the wheel well (he wanted more capacity).
morrisman1, Apr 6, 4:18pm
Heres what ive come up with. Only cost about $20 of welding supplies and an afternoon, so nothing lost really if it doesn't work. Had to chase some leaks but got them all now. Sneaky beggars they are.
Had I used a TIG welder im sure it would have been prettier but who really cares, Its a budget build race car. I would have had to call in a favour to use a tig while I had a perfectly good MIG sitting there.
http://i264.photobucket.com/albums/ii200/morrisman1/20150405_180230_zpscjsybe3v.jpg
safteystv, Mar 27, 4:07am
a" mini" fuel tank . or motor cycle one
