94 HIACE SUPERCUSTOM DASH LIGHTS, REVS NOT WORKING
ali.m,
Dec 12, 1:45pm
Took my centre console out and turned the key forgetting that i hadnt pluged the plugs for the centre console in!. All the lights came on as usual on the dash but then all went off except the battery and door light also the rev tacho is a no go, the van starts and runs fine though. Is this a fuse or worse?
ml6989,
Dec 12, 8:39pm
By centre console do you mean the speedo / rev counter assembly? I would go back and check that all the plugs are pushed in and located correctly.
still_game,
Dec 13, 7:07am
No by centre console i mean between the 2 front seats and yup its all plugged in now but makes no difference
Jun 24, 5:14am
So, were you pulling apart the refrigeration unit? Anyway, I'd check that none of the wires were pinched and definitely check the fuses first.
