I'm no expert. I have just done a compression test and 1 - 5 cylinders are 180 psi and number 6 cylinder is 155 psi. What would be the damage ?
msigg,
Oct 1, 5:06pm
Maybe valve seating not as good, maybe just bit more wear in cylinder, I wouldn't worry about it if its going good. Just use it.
bwg11,
Oct 1, 5:56pm
As above, but probably wouldn't hurt to check valve clearances, in case of the unlikely event one has tightened up.
m16d,
Oct 1, 6:57pm
Errr. is this a 2 smoker outboard,,,?
unclejake,
Oct 1, 7:44pm
If it is an outboard I'd be cautious of corrosion around the exhaust port if #6 is at the bottom
It might be a Mercruiser motor - which is basically a car engine anyway
EDIT: I guess it's a GM 262cui block Mercuriser (four stroke horizontal V6)
bretals,
Apr 7, 8:27pm
Yes four stroke horizontal V6 motor
