Holden Barina won't start
Page 5 / 6
gph1961, Mar 12, 6:54am
yup,when you find yourself in a hole. stop digging
gazzat22, Mar 13, 12:14am
If you do check filter take intrade,s advice #103. Any mobile mechanic you can call on ?.You could try -- if you havent giving it a bit of Engine Start spray.
intrade, Mar 17, 9:51pm
you need a mechanic to check fuelpump. as it seems above your paygrade metaphorically speaking . you dont want fire when all it needs is a pump like this toyota
https://www.youtube.com/watch?v=vMoFcotbOMc
intrade, Mar 17, 9:56pm
he did and it fired just like the above video. i said it has no fuel or it has the bypass ignitioni if it gets fuel.
its only them 2 things and i say its fuelpump or fuilpump circuit issue. dont f. k with it if you got no clue you can damage electronics if you give power to wrong things. competent mechanic 1h charge . we cant easy get fuelpump modules like they do in usa for cheap on top.
nzrose7, Mar 17, 10:21pm
I had driven 20 k across town, stopped to get something, wouldn't start - new battery required.
karlo, Mar 18, 10:30am
Nothing wrong with fuel pump - I can hear it running.
kazbanz, Mar 18, 8:39pm
Ok lets just go through this
96 Holden Barina
Running perfectly -Left in storage for 3 weeks
Cambelt "just" changed,
Engine starts very briefly (for a second or two) and then stops. BUT no evidence in U tube vid
Battery is good, ---Yet is turning over very very slowly in u tube vid
plenty of fuel, -Yet turning it over the new plugs are dry
friend of mine cleaned the spark plugs and a distributor,- BUT original spark plugs were black and sooted up
"All" fuses checked and ok--BY ALL do you mean the ones in the cabin AND under the bonnet?
but still no go.
kazbanz, Mar 18, 8:58pm
I would appreciate if a picture of the key was posted up.
My gut is that the car has imobiliser chip from factory.
Key isn't talking to the car so the fuel pump is off.
tygertung, Mar 19, 8:43am
Doesn't mean it is pumping though.
There is an old saying though "9 out of 10 fuel problems are electrical".
pettal, Mar 19, 9:35am
if it's a manual = tow start it
strobo, Mar 19, 6:10pm
Had a difficult fuel system (sp) last year with such problems but it was on a nissan micra gen 1 . much and much the same type of fuel system.It was hard to start or no start at all .did the usual ground work , went over it and decided to pull a sealed cover off the side of the throttle body there is a circuit board and resoldered all the dry joints ,resealed it. Adjusted the TPS. Pulled the Fuel pump relay ,but not the fuse, cranked it a few times then refitted the pump relay ,and cranked to go.It ran like a swiss clock.The owner had problems with the car for a long time and looked at by several people many times at different places and was told was timing issues etc and $$$$.
strobo, Mar 19, 6:16pm
Volume v pressure ."I can hear the pump ticking " so it must be ok. = false assumption!
karlo, Mar 20, 6:23am
Some people think cambelt has skipped a notch (or two) so I won't touch it.
karlo, Mar 20, 6:26am
Did I mention that on a scale from 1 to 100 my car "knowledge" is about 1.5 (and I am being generous here).
karlo, Mar 20, 7:06am
I's a 1995 model car and has no immobiliser.
https://trademe.tmcdn.co.nz/photoserver/full/1509281109.jpg
redhead18, Mar 20, 7:30am
. karlo wrote:
Battery charged, spark plugs look good to me:
https://trademe.tmcdn.co.nz/photoserver/full/1502075332.jpg[
/quote]
Really? Surely you jest dear Sir
As to your claim Engine starts very briefly (for a second or two) and then stops. [post#1]
We do NOT see this in your video [post#53]
So perhaps ALL spark plugs removed and suitably earthed and high tension leads fitted and a video showing if they actually produce spark when engine cranked or not?
Quote
redhead18 (1124 1124 positive feedback) 4:43 pm, Mon 8 Mar #74
strobo, Mar 22, 7:22am
https://www.youtube.com/watch?v=ijc1eJVR9Qw
There is a hole in my bucket dear Liza a hole !
gazzat22, Mar 22, 8:44pm
Contact whoever changed the cambelt.!
intrade, Mar 22, 8:57pm
what fuel did you put in last ? because my mates telstar now also wont start and i think he put G fuel 91 i was thinking the 91 was not ethanol con-terminated . i call it that i-m-o
karlo, May 6, 7:45pm
FINAL VERDICT: Because INCORRECT new water pump was installed, cambelt skipped and prevented the car from starting. Luckily enough a catastrophic engine failure did not occur (see water pump comparison pic):
https://trademe.tmcdn.co.nz/photoserver/full/1536010676.jpg
gazzat22, May 6, 8:31pm
It was a long long journey but you got there in the end #124
kazbanz, May 6, 8:39pm
Totally different tooth profile.How on earth could that have been missed/
intrade, May 7, 9:06pm
So who changed that waterpump and who found the problem. If i recall right i told you ages ago to check timing that was obviously not done correct to take this long to find the problem.
strobo, May 7, 9:30pm
There was an obvious connection between the last job done and the devloped problem that several pointed out . Work that was done by an incompetent person with passion fingers it seems!
kazbanz, Aug 11, 1:12pm
I don't agree with you. I bet it was done right at the time. -Have a look at the two water pump pictures OP posted. One has the opel half round teeth the other the traditional "square" teeth. I hate to imagine what the belt was off of.
