Kia with 200 000 hard km has developed its first issue,, not charging. Do auto sparkies still re-con alternators or just replace nowadays? Cheers.
rover79,
Nov 17, 8:17am
I had a Nisan one done A few years ago and cost me 350 but a new one cost 650 Then a few years before that I had a battery outfit clean one up and bench tested it and reckoned that it was fine and charge me 180, a week later light started coming on again. So I bought a secondhand one for 150
cattleshed,
Nov 17, 9:44am
Important to know the details. What year is it and what model Kia?
mber2,
Nov 17, 9:52am
Get a few quotes as it probably is just replace brushes.
muzz67,
Nov 17, 4:54pm
2010 Rio
msigg,
Nov 17, 6:05pm
Replace. Easy done.
clark20,
Nov 17, 6:29pm
Visit a good Auto Electrician and find out
Nov 17, 6:43pm
If you're going to be getting rid of the car shortly just putting a second hand one on will probably be the best. Compete new alternators can either be ridiculously cheap or rudely expensive depending on what it is and how common it is, the same applies to internal parts, if they're even available. If you can get a photo of the ID label on it and start googling the numbers or give the info to an auto sparky you will soon get an idea of what route is best to take.
cattleshed,
Nov 18, 3:36am
When you say not charging. what is your evidence for that claim? Let's say the battery is going flat. There can be reasons for that other than a faulty alternator. Eg a loose fan belt or a faulty battery. Another possibility is that something is draining the power even though the car is locked up. Sure an alternator can fail at 200k and 10 years but they often last a lot longer too.
cattleshed,
Nov 18, 3:37am
But not necessarily fixed.
ash4561,
Oct 24, 2:19am
Depends if 600 or 300 to replace. I used to think they were all expensive to replace but some under 300 new.
