Hilux speedo
jane38, Apr 8, 5:58am
Hello have fitted a new speedo cable to a 2001 Hilux and now the speedo needle jumps around until 60 kmh when it settles down.Any ideas?Cheers
franc123, Apr 8, 6:10am
It is routed correctly and was definitely lubed well when you fitted it?
jane38, Apr 8, 6:15am
Yes it was.Dont understand why it settles down at 60 kmh where if it was nt lubed it would jump around right through the ks?
bigfatmat1, Apr 8, 6:52am
Cable is too long grind a couple of mm off the end if it's a squared end, the internal part not the external part
jane38, Apr 8, 6:58am
Will have a look in the morning and compare it to the old one.Thanks
bigfatmat1, Aug 24, 11:49pm
you probably won't notice the diff if it's only a couple of mm
