is there much in replacing one! looks pretty straight forward.
carmedic,
Mar 31, 6:27pm
Yes pretty straight forward, you probably won??
whqqsh,
Mar 31, 6:54pm
puller is a must (made one up) & Ive made a bar with a welded on socket to flick the starter to get the bolt out too, bloody had to find a place to lock the motor up if just undoing it with a socket.
im_andrew,
Sep 14, 8:17am
Pulling the starter off and locking the ring gear with a screw driver is an option, as is undoing the plate in the bellhousing and locking against one of the torque converter bolts. But I find a powerbar against the chassis rail and a flick of the starter to be easiest, too
