!Help with 91 Pulsar!
_roxxra_, Mar 30, 11:26am
Hi all,
So a month ago I bought a 1991 Nissan Pulsar M1R 2 Door Hatchback (auto trans)
Recently a couple of troubles have come up
1. Exhaust has started leaking at the exhaust tip
2. Transmission wont hit second gear unless I use the '2' then put into second. I only have to do this the first time i drive it, every other time its been fine to just use 'D'.
3. The revs seem to drop then shake when i reach a red light. It doesn't cut out, just drops to around 400-600 revs then back up again to 800, then keeps doing this until the light turns green.
I only drive it to and from classes four days a week MAX, and Im definitely no boy racer or anything, so I really don't know what could cause this.
I am hoping to find out any possible reasons for these happening, and, fingers crossed, it's not anything major. So absolutely any help would be very greatly appreciated.
legacy1992, Mar 30, 11:30am
What do you mean by exhaust leaking! That could just be condensation coming out of the pipe. As for the rev thing, that could be anything maybe dirty spark plugs, clogged injectors, but it probably has carbies anyway.
_roxxra_, Mar 30, 11:36am
Thanks for the reply, Well it drips at the tip, the previous owner put an aftermarket exhaust tip on (for some reason) and it drips water.
inkapuka, Mar 30, 12:00pm
Thats condensation most cars do that when cold
inkapuka, Mar 30, 12:02pm
buy some new spark plugs and then let us know if its running any healthier
_roxxra_, Mar 30, 12:11pm
Thanks for that, Ill go buy some today. What do you think about the transmission! Thats the thing that Im scared of the most.
mugenb20b, Mar 30, 12:14pm
1. Don't worry about it.
2. Transmission service may help.
3. Is the engine carburetted or EFi!
inkapuka, Mar 30, 12:45pm
Yep get the trans serviced
mcfc11, Mar 30, 1:54pm
1991 = Scrap!
intrade, Mar 30, 2:38pm
yup auto trans service with filter and sump gasket replacment is the first thing to spend the money on as when that is dead the car can go to the metalcrusher anyhow.
austingtir, Mar 30, 3:42pm
mcfc11 = Idiot!
_roxxra_, Mar 30, 4:29pm
How do I tell if it is an EFI or carburetted!
intrade, Mar 30, 4:41pm
get the auto trans serviced at a automatic trans rebuild place with newfilter in sump gasket and fluid flush. who cares if its efi or carburettor you can tow it to the tip if the automatic transmission fails .
intrade, Mar 30, 4:43pm
you better pull your auto trans dipstik while engine is running and check what the fluid level is and what the colour looks like and post that on here. there will be hot and cold mark. do that and report back.
here i googled a basic video on how and what to do
http://www.youtube.com/watch!v=gm4j2BL7m0Y
210sback, Mar 30, 4:54pm
Time to upgrade.
mugenb20b, Mar 30, 4:56pm
It will be easier to give advice on how to fix problem number 3 if we knew what type of fuel delivery system the engine has.
mugenb20b, Mar 30, 4:57pm
Can you post a pic of the engine bay!
_roxxra_, Mar 30, 5:14pm
Umm Im not sure how to do that. but I can go out and tell you things if you can describe where and what I'm looking for.
_roxxra_, Mar 30, 5:15pm
I've already done all that, the colour is not red, but its definitely not black either
intrade, Mar 30, 5:25pm
mugenb20b, Mar 30, 5:50pm
If it looks like the one in post #21, it will be carburetted.
_roxxra_, Mar 30, 5:55pm
It does, but the parts around the engine are different. For one the black thing on top isn't black, its silver and has four pipes going towards the cabin. But the engine, and the manifold cover and the yellow dipstick are all in the same position. I hope that helps, and sorry if Im being confusing.
intrade, Mar 30, 6:02pm
_roxxra_, Mar 30, 6:10pm
Yes, thats the one, It looks exactly like the images in post #24 & post #25
intrade, Mar 30, 6:12pm
yea well its fuel injected then lol
