Up date time The scan came up with something like a p0345 fault. Left hand cam sensor. I still have no idea what the slip light means or what connection there is between a cam sensor and the traction control
Sep 29, 5:49am
what scantool and did they scope the sensor with a digital oscilloscope for fault?
bumfacingdown,
Sep 29, 5:54am
Again, I can't tell you what the name of the scan tool was but yes the sensor was tested with an oscilloscope in situ.
Sep 29, 6:10am
so sensor replaced and now fine? other faults can get set because they are on a same network or when the engine plays up so does the gears in a transmission as they are driven bye the engine . setting codes. its called logical backtracking of plausebility. Then testing and then making a call on a repair solution.
snoopy221,
Sep 29, 6:13am
***Likes***
bumfacingdown,
Sep 29, 6:14am
Yep, new sensor and faults gone, car back to as was. But, what is the Slip thingy?
bigfatmat1,
Sep 29, 7:51am
It's saying because there is a engine fault we are disabling these other systems because we need that sensor information
Oct 1, 12:20am
or in my instance my astra had 3 transmission codes one was transmission torque converter speed inplausible another svs via can . and something else . the problem was a missfire on cilinder 2 and sometimes on cilinder 4 . this caused the engine speed rotation to be mon constant non linear during the missfire events and the speed sensor on the torque converter detected it and started to set transmission codes. Absolute 0 things wrong with the transmission. the codes are just a byproduct of a other cause.
bumfacingdown,
Oct 1, 12:24am
Thanks BFM, unfortunately with out the full knowledge of how these things work it still leaves me in awe. You don't know what the slip light is for do you, never seen it come on even when TC is being used (or not)
bumfacingdown,
Oct 1, 12:26am
"the codes are just a byproduct of a other cause" And there in lies a problem with so much computing being done in cars and so many computers "talking" to each other
bigfatmat1,
Oct 1, 12:47am
it normally comes on during loss of traction but could be on if tc light or abs light is on. Not uncommon. If you have any queries pop into my work and discuss or scan. Happy to help
bumfacingdown,
Oct 1, 1:20am
Cheers, thanks BFM, just never saw that light comiong on when driving, have tested out the TC and tested it with out, still not seen it. Keep you in mind although fingers Xed your skills will not be needed (alas, its a car with computers so probably will)
bumfacingdown,
Sep 15, 9:51pm
That stay on. Engine check Slip TCon Any clues, while it is at the Drs, as to what they commonly indicate
toyboy3,
Sep 15, 9:55pm
bumfacingdown,
Sep 15, 9:56pm
Thanks, may have figured that part out though
poppy62,
Sep 16, 12:16am
Strange why the resident Nissan buff never seems to comment on any technical inquiries. Guess he's watching "stangs" lining up against Renault Twizzys on you tube. Anyway BFD this link may give you a clue or 3.
Thanks poppy, seems to cover anything from dirty sensor contact to "you need a new engine" Ahh well, should just be patient and await the Drs report
Sep 16, 3:47am
with that many fault lights I'd be thinking dudd battery first.
bumfacingdown,
Sep 16, 4:18am
Battery OK and not very old, apparently removing and reconnecting did not clear lights Got it back from local garage, which unfortunately is not a Nissan agent and their computer would not talk to the car computer so at this stage none the wiser as to why
electromic,
Sep 16, 4:26am
You're joking! Even the little bosh unit at supercheep will 'talk' to your stagea computer. There are some things it can't do but would give you a good idea of what is wrong.
bumfacingdown,
Sep 16, 4:32am
Can only go by what the mechanic told his boss. Seemed strange to me but I would also like to know if grand garages, which are a franchise after all, are not allowed to have opposition friendly gear
vtecintegra,
Sep 16, 4:32am
I had some weird issues with a V35 Skyline - turns out the body control module (down under the battery tray) had got a bit damp.
There are little drains down there that tend to get blocked up so it'd be worth a look.
bumfacingdown,
Sep 16, 4:39am
Hmmm, interesting, will have a look in daylight tomorrow, battery just in front of windscreen left hand side, the same as Skyline?
vtecintegra,
Sep 16, 4:54am
Yep they're basically the same car.
Sep 16, 5:16am
do you remember what i told you about 2005 nissan.
